Abstract : Adaptation is usually considered as a complex task when the similarity between the source and target problems is not obvious. This paper explains how this complex task can be decomposed in simpler adaptation subtasks thanks to the notion of reformulation.
https://hal.inria.fr/inria-00098776 Contributor : Publications LoriaConnect in order to contact the contributor Submitted on : Tuesday, September 26, 2006 - 8:35:08 AM Last modification on : Wednesday, February 2, 2022 - 3:51:48 PM Long-term archiving on: : Wednesday, March 29, 2017 - 12:39:24 PM
Jean Lieber. Reformulations and Adaptation Decomposition. International Conference on Case-Based Reasoning - ICCBR'99, Lieber, Jean et Melis, Erica et Mille, Alain et Napoli, Amedeo, 1999, Munich, Germany, 7 p. ⟨inria-00098776⟩
