New interface
Conference papers
Towards safer aliasing with the Eiffel language
Olivier Zendra 1 Dominique Colnet 1
1 ECOO - Environment for cooperation
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : The SmallEiffel compiler makes intensive use of aliasing in order to achieve very good performance both in terms of memory and execution time. This technique is very appropriate for compilation, but can also be applied to a wide range of applications. Thanks to the design by contract capabilities of the Eiffel language, aliasing can be handled very safely. The singleton pattern appears to be crucial in implementing alias provider objects. We propose an efficient implementation of this pattern made easy by some Eiffel idioms.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00098844
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 8:39:08 AM
Last modification on : Friday, February 4, 2022 - 3:21:52 AM
Identifiers
  • HAL Id : inria-00098844, version 1
Collections
Citation
Olivier Zendra, Dominique Colnet. Towards safer aliasing with the Eiffel language. Intercontinental Workshop on Aliasing in Object-Oriented Systems IWAOOS'99 - ECOOP'99 workshop reader, 1999, Lisbonne, Portugal, pp.153. ⟨inria-00098844⟩
Share
Metrics
Record views
67
