Stabbing information of a simple polygon - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Applied Mathematics Année : 1999
The purpose of this paper is to investigate a new combinatorial object describing the structure of a simple polygon and compare it to other well-known objects such as the internal and external visibility graphs, the convex hull and the order type of the vertex set. We call the new object the stabbing information. In fact, we define three variations of the stabbing information, strong, weak and labelled, and explore the relationships among them. The main result of the paper is that strong stabbing information is sufficient to recover the convex hull, the internal and external visibility graphs and to determine which vertices are reflex and it is not sufficient to recover the order type of the vertex set. We also show that the labelled stabbing information is equivalent to the order type. We give algorithms for computing each of these new structures.
Autre [cs.OH]
Fichier non déposé
inria-00098848 , version 1 (26-09-2006)
  • HAL Id : inria-00098848 , version 1
Hazel Everett, Ferran Hurtado, Marc Noy. Stabbing information of a simple polygon. Discrete Applied Mathematics, 1999, 91 (1-3), pp.67-92. ⟨inria-00098848⟩
69 Consultations
0 Téléchargements
