Abstract : The elementary closure $P'$ of a polyhedron $P$ is the intersection of $P$ with all its Gomory-Chvátal cutting planes. $P'$ is a rational polyhedron provided that $P$ is rational. The known bounds for the number of inequalities defining $P'$ are exponential, even in fixed dimension. We show that the number of inequalities needed to describe the elementary closure of a rational polyhedron is polynomially bounded in fixed dimension. If $P$ is a simplicial cone, we construct a polytope $Q$, whose integral elements correspond to cutting planes of $P$. The vertices of the integer hull $Q_I$ include the facets of $P'$. A polynomial upper bound on their number can be obtained by applying a result of Cook et al. Finally, we present a polynomial algorithm in varying dimension, which computes cutting planes for a simplicial cone that correspond to vertices of $Q_I$.
