HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
A Minimum Cross-Entropy Approach to Hidden Markov Model Adaptation
Mohamed Afify 1 Yifan Gong Jean-Paul Haton 2
1 PAROLE - Analysis, perception and recognition of speech
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
2 MAIA - Autonomous intelligent machine
Abstract : An adaptation algorithm using the theoretically optimal maximum a posteriori (MAP) formulation, and at the same time accounting for parameter correlation between different classes is desirables, especially when using sparse adaptation data. However, a direct implementation of such an approach may be prohibitive in many practical situations. In this letter, we present an algorithm that approximates the above mentioned correlated MAP algorithm by iteratively maximizing the set of posterior marginals. With some simplifying assumptions, expression for these marginals are then derived, using the principle of minimum cross-entropy. The resulting algorithm is simple, and includes conventional MAP estimation as a special case. The utility of the proposed method is tested in adaptation experiments for an alphabet recognition task.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00098969
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 8:40:56 AM
Last modification on : Friday, February 26, 2021 - 3:28:06 PM
Identifiers
  • HAL Id : inria-00098969, version 1
Collections
Citation
Mohamed Afify, Yifan Gong, Jean-Paul Haton. A Minimum Cross-Entropy Approach to Hidden Markov Model Adaptation. IEEE Signal Processing Letters, Institute of Electrical and Electronics Engineers, 1999, 6 (6), pp.132-134. ⟨inria-00098969⟩
Share
Metrics
Record views
90
