Specifying Interactions in Cooperative Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
Samir Tata
  • Fonction : Auteur
  • PersonId : 835351
Gérôme Canals
  • Fonction : Auteur
  • PersonId : 830484
Claude Godart
  • Fonction : Auteur
  • PersonId : 830462
  • IdRef : 031091733
Our research is concerned with a particular class of cooperative applications, which aggregate several partners around a common project, and for the duration of this project. Cooperation in these applications occurs in the more common case through the sharing of persistent objects: the products of the project. Partners share and modify these products, alternating periods of isolated work with periods of interaction. This paper introduces a formal framework to specify such interactions in a simple way by combining basic cooperation modes. A cooperation mode results from a combination of dependencies between two activities with regards to an object, or from the combination of cooperation modes in a more complex one.
Fichier non déposé
inria-00098972 , version 1 (26-09-2006)
  • HAL Id : inria-00098972 , version 1
Samir Tata, Gérôme Canals, Claude Godart. Specifying Interactions in Cooperative Applications. Eleventh International Conference on Software Engineering & Knowledge Engineering, 1999, Kaiserslautern Germany. ⟨inria-00098972⟩
130 Consultations
0 Téléchargements
