Using Temporal Logic to Specify Interactions in Cooperative Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
Samir Tata
  • Fonction : Auteur
  • PersonId : 835351
Gérôme Canals
  • Fonction : Auteur
  • PersonId : 830484
Claude Godart
  • Fonction : Auteur
  • PersonId : 830462
  • IdRef : 031091733
Our research deals with a particular class of cooperative applications, which aggregate several partners around a common project, and for the duration of this project. Cooperation in these applications occurs in the most common case through the sharing of persistent objects: the products of the project. Partners share and modify these products, alternating periods of isolated work with periods of interaction. This paper introduces a formal framework to specify in temporal logic such interactions in a simple way by combining basic cooperation modes. A cooperation mode results from a combination of dependencies between two activities with regards to an object, or from the combination of cooperation modes in a more complex one. Dependencies are expressed as logical predicates. Complex interactions and cooperation modes are thus described as temporal logic formulae built from these predicates.
Fichier non déposé
inria-00098973 , version 1 (26-09-2006)
  • HAL Id : inria-00098973 , version 1
Samir Tata, Gérôme Canals, Claude Godart. Using Temporal Logic to Specify Interactions in Cooperative Applications. The AAAI'99 Symposium on Modal & Temporal Logic-based Planning for Open Networked Multimedia Systems - PONMS'99, Nov 1999, North Falmouth, Massachusetts, USA, 10 p. ⟨inria-00098973⟩
69 Consultations
0 Téléchargements
