Bringing Metacomputing to Scilab - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
Claude Gomez
Serge Steer
  • Fonction : Auteur
Stéphane Ubéda
Scilab, developed at INRIA in the Méta2 project is a software similar to Matlab that allows scientific applications to be developed using an interactive environment on a workstation running Unix or Windows. In this paper, we present the current version of \scip, a extension of this software that supports the execution of parallel jobs within \sci. Using simple commands and the same interface as \sci, \scip\ allows users to start \sci\ on a parallel machine or a network of workstations (NOWs), therefore giving access to the computation power and huge aggregate memory sizes. From the \sci\ interactive environment, users can spawn several other \sci\ processes, executing remote \sci\ scripts, which can then communicate between each other. Finally, processes can print/plot their results. There are many research directions around this project and we give an overview of the current and future developments.
Fichier non déposé
inria-00099007 , version 1 (26-09-2006)
  • HAL Id : inria-00099007 , version 1
Frédéric Desprez, Eric Fleury, Claude Gomez, Serge Steer, Stéphane Ubéda. Bringing Metacomputing to Scilab. Computer Aided Control System Design - CACSd' 99, Aug 1999, Hawaï, USA, 6 p. ⟨inria-00099007⟩
163 Consultations
0 Téléchargements
