Improving acoustic-to-articulatory inversion by using hypercube codebooks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
This paper presents an articulatory codebook construction method which gives a good space coverage with a limited number of points. For this aim, the articulatory space is decomposed into regions, represented by hypercubes, where the mapping is quasi-linear. The codebook, therefore, is a collection of hypercubes. The main quality of this codebook is that it respects the non-linear nature of the articulatory-to-acoustic mapping. We also present an inversion method using this hypercube codebook.
A00-R-239.pdf (601.5 Ko) Télécharger le fichier
inria-00099051 , version 1 (26-09-2006)
  • HAL Id : inria-00099051 , version 1
Slim Ouni, Yves Laprie. Improving acoustic-to-articulatory inversion by using hypercube codebooks. International Conference on Spoken Language Processing - ICSLP2000, 2000, Beijing, Chine, pp.178-181. ⟨inria-00099051⟩
103 Consultations
121 Téléchargements
