An Object-Oriented Modeling of Co-operative Multimedia Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
Co-operative multimedia systems are characterized by different properties (interactivity, group communication support and QoS sensitiveness). In addition to constraints that can be dealt with in multimedia systems (particularly synchronisation and communication constraints), integrity constraints can be defined and verified, and also temporal constraints can be described in the definition of multimedia flows. In this paper, we present a model to deal with multimedia constraints representation. We propose a model that allows the description of the constraint and the characterization of multimedia applications in the context of co-operative environments. Our model defines a framework with different functionality levels to tackle the complexity of distributed multimedia systems. We identify the entities and describe their function. We define a set of services associated with each level. We describe these services, and we illustarte, by an example, message exchanges between entities.
Fichier non déposé
inria-00099108 , version 1 (26-09-2006)
  • HAL Id : inria-00099108 , version 1
Gladys Diaz, Jean-Pierre Thomesse, Zoubir Mammeri. An Object-Oriented Modeling of Co-operative Multimedia Systems. 26th Euromicro Conference - Informatics: Inventing the future, Euromicro Workshop on multimedia and Telecommunications, 2000, Maastricht/Hollande, pp.166-173. ⟨inria-00099108⟩
105 Consultations
0 Téléchargements
