HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Introduction to the constraint language NCL
Jianyang Zhou 1
1 PROTHEO - Constraints, automatic deduction and software properties proofs
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : The design, implementation and application of a natural constraint language NCLare presented. At the solver level, to support the solving of a large scope of combinatorial problems, a rich set of conventional constraints is defined within a constraint framework that strongly combines Boolean logic, integer constraints and set reasoning over finite domains. The basic computation model for solving conjunctions of elementary constraints with possible existential and universal quantifications is described using rewrite rules. At the language level, to upgrade the expressive power, a natural syntax (context-dependent), which completely adopts mathematical notations, is designed. To enhance the constraint handling capability, quantification, logical switch, referencing mechanism, global/dynamic constraints, meta expressions, multi-criteria optimization, and search specifications are cooperatively introduced in a single constraint system. Compared to existing modeling languages, a strong feature of NCLis: Data, constraints and control are fully integrated and are clearly separable. Especially, though NCLdeals with several data types such as Boolean, integer, set, index, reference, array and tuple, there is no need to declare data explicitly. This context-sensitive data typing makes NCLprograms direct, concise and liberal.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00099184
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 8:51:35 AM
Last modification on : Friday, February 4, 2022 - 3:33:12 AM
Identifiers
  • HAL Id : inria-00099184, version 1
Collections
Citation
Jianyang Zhou. Introduction to the constraint language NCL. Journal of Logic Programming, Elsevier, 2000, 45 (1-3), pp.71-103. ⟨inria-00099184⟩
Share
Metrics
Record views
305
