New interface
Conference papers
What can XML do for information retrieval on the WEB?
Emmanuel Nauer 1 Rim Al Hulou 1 Amedeo Napoli 1
1 ORPAILLEUR - Knowledge representation, reasonning
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : In this paper, we propose an analysis of the links existing between (1) semi-structured data (or SSD), i.e. rough and heterogeneous data without fixed structure (2) XML, the language of description of textual documents (3) object-based representation systems (OBRS). The manipulation of SSD comes from several needs such as data integration, information retrieval on the Web and text mining. Due to its characteristics, XML may be used for describing SSD and can be considered as a bridge between SSD and OBRS, OBRS being mainly used for their reasoning capabilities. We conclude the paper with a discussion enlightening the benefits of using XML and OBRS for manipulating SSD and solving problems involving SSD.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00099200
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 8:51:42 AM
Last modification on : Thursday, April 7, 2022 - 3:08:58 AM
Identifiers
  • HAL Id : inria-00099200, version 1
Collections
Citation
Emmanuel Nauer, Rim Al Hulou, Amedeo Napoli. What can XML do for information retrieval on the WEB?. Proceedings of the 7th International Workshop on Knowledge Representation meets Databases - KRDB'2000, 2000, Berlin/Germany, pp.101--114. ⟨inria-00099200⟩
Share
Metrics
Record views
76
