Connection Methods in Linear Logic and Proof nets Construction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 2000
Didier Galmiche
Linear logic (LL) is the logical foundation of some type-theoretic languages and also of environments for specification and theorem proving. In this paper, we analyse the relationships between the proof net notion of LL and the connection notion used for efficient proof-search in different logics. Aiming at using proof nets as a tool for automated deduction in linear logic, we define a connection-based characterization of provability in Multiplicative Linear Logic (MLL). We show that an algorithm for proof net construction can be seen as a proof-search connection method. This central result is illustrated with a specific algorithm that is able to construct, for a provable MLL sequent,a set of connections, a proof net and a sequent proof. From these results we expect to extend to other LL fragments, we analyse what happens with the additive connectives of LL by tackling the additive fragment in a similar way.
inria-00099205 , version 1 (26-09-2006)
Didier Galmiche. Connection Methods in Linear Logic and Proof nets Construction. Theoretical Computer Science, 2000, 232 (1-2), pp.231-272. ⟨10.1016/S0304-3975(99)00176-0⟩. ⟨inria-00099205⟩
81 Consultations
0 Téléchargements
