Network Oriented Application Harmonisation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Contrat/Projet) Année : 2000
The european standard EN 50170 for industrial Fieldbus recognises three different communication systems. A common open platform will significantly reduce the costs for development, integration and use of automation systems. The main objectives of NOAH are : the specification of Harmonized field Device application and communication interface The validation of specifications through a pilot implementation.
Autre [cs.OH]
Fichier non déposé
inria-00099250 , version 1 (26-09-2006)
  • HAL Id : inria-00099250 , version 1
Olivier Jaray, Jean-Pierre Thomesse. Network Oriented Application Harmonisation. [Contract] A00-R-403 || jaray00c, 2000. ⟨inria-00099250⟩
56 Consultations
0 Téléchargements
