A Data-Parallel Implementation of the Gauss-Seidel Iteration Method Applied to the Sliding Box Problem
Jacques Jaray 1 Olivier Galibert 1
1 MODEL - MODEL (Méthodes formelles et applications)
LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : The data-parallel programming is convenient for numerical computation dealing with data collections like arrays. Physicists use very efficient sequential programs to simulate physical processes, but such programs can not be easily adapted to parallel architectures. The Gauss-Seidel fix point computation is an example. This paper aims at showing how data-parallel modeling and programming helps in redesigning sequential programs for an efficient parallel implementation whatever the parallel architecture is.
Type de document :
Rapport
[Intern report] A00-R-085 || jaray00a, 2000, 14 p
Liste complète des métadonnées
https://hal.inria.fr/inria-00099296
Contributeur : Publications Loria <>
Soumis le : mardi 26 septembre 2006 - 08:52:35
Dernière modification le : mardi 24 avril 2018 - 13:34:48
  • HAL Id : inria-00099296, version 1
Collections
Citation
Jacques Jaray, Olivier Galibert. A Data-Parallel Implementation of the Gauss-Seidel Iteration Method Applied to the Sliding Box Problem. [Intern report] A00-R-085 || jaray00a, 2000, 14 p. 〈inria-00099296〉
Métriques
Consultations de la notice
119
