HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Fixing Race Condition Errors with Formal Techniques. A Case Study in Concurrent Java Programming
Jacques Jaray 1
1 MODEL - MODEL (Méthodes formelles et applications)
LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : Concurrent programming is getting popular through the use of Java threads for instance. On the other hand sequential programmers make a sparse use of formal techniques like assertions and proof to produce the code. It is well known that concurrent programs are much more difficult to produce right than the sequential one. Testing is of poor help as we are not sure to replay testing conditions and we are subject to race conditions whose consequence is that a program may runon a machine but not on another one. Model checking appeared efficient and easy to make use in fixing an error of synchronization.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00099298
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 8:52:35 AM
Last modification on : Friday, February 26, 2021 - 3:28:08 PM
Identifiers
  • HAL Id : inria-00099298, version 1
Collections
Citation
Jacques Jaray. Fixing Race Condition Errors with Formal Techniques. A Case Study in Concurrent Java Programming. [Intern report] A00-R-086 || jaray00b, 2000, 13 p. ⟨inria-00099298⟩
Share
Metrics
Record views
67
