The Eulerian stretch of a digraph and the ending guarantee of a convergence routing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2000
In this paper, we focus on convergence packet routing techniques in a network, obtained from an Eulerian routing in the digraph modeling the target network. Given an Eulerian circuit $\cal C$ in a digraph $G$, we consider the maximal number $diamW_{\cal C}$ of arcs that a packet has to follow on $\cal C$ from its origin to its destination (we talk about the {\em ending guarantee} of the routing). We consider the {\em Eulerian diameter of $G$} as defined by ${\cal E}(G)=\min\limits_{{\cal C}? Eul(G)} diamW_{\cal C}$, where $Eul(G)$ is the set of all the Eulerian circuits in $G$. After giving a preliminary result about the complexity of finding ${\cal E}(G)$ for any digraph $G$, we give some lower and upper bounds of this parameter. We conclude by giving some families of digraphs having good Eulerian diameter.
Fichier non déposé
inria-00099331 , version 1 (26-09-2006)
  • HAL Id : inria-00099331 , version 1
Dominique Barth, Pascal Berthomé, Johanne Cohen. The Eulerian stretch of a digraph and the ending guarantee of a convergence routing. [Intern report] A00-R-400 || barth00a, 2000, 22 p. ⟨inria-00099331⟩
100 Consultations
0 Téléchargements
