Adding Flexibility in a Cooperative Workflow Execution Engine - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Daniela Grigori
  • Fonction : Auteur
  • PersonId : 835377
Hala Skaf-Molli
François Charoy
This paper describes an approach to support cooperation in workflow based on the combination of a cooperative transaction protocol (COO) and a traditional workflow model. This combination allows activities to exchange data during their execution. It also allows some activities to start in advance on the predefined control flow (anticipate) and to exchange results with its preceding activities. All these communications of draft results are done under the control of the extended cooperation protocol and under the responsibility of the users. This allows for more flexibility regarding the actual execution of the process model while keeping some control on the way the exchanges are done.
Autre [cs.OH]
Fichier non déposé
inria-00099361 , version 1 (26-09-2006)
  • HAL Id : inria-00099361 , version 1
Daniela Grigori, Hala Skaf-Molli, François Charoy. Adding Flexibility in a Cooperative Workflow Execution Engine. 8th International Conference on High Performance Computing & Networking Europe - HPCN Europe 2000, May 2002, Amsterdam, Hollande, pp.227-236. ⟨inria-00099361⟩
62 Consultations
0 Téléchargements
