HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Building Efficient Partial Plans using Markov Decision Processes
Pierre Laroche 1
1 MAIA - Autonomous intelligent machine
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : Markov Decision Processes (MDP) have been widely used as a framework for planning under uncertainty. They allow to compute optimal sequences of actions in order to achieve a given goal, accounting for actuators uncertainties. But algorithms classically used to solve MDPs are intractable for problems requiring a large state space. Plans are computed considering the whole state space, without using any knowledge about the initial state of the problem. In this paper, we propose a new technique to build partial plans for a mobile robot, considering only a restricted MDP, which contains a small set of states composing a path between the initial state and the goal state. To ensure good quality of the solution, the path has to be very similar to the one which would have been computed on the whole environment. We present in this paper a new method to compute partial plans, showing that representing the environment as a directed graph can be very helpful to find near-optimal paths. Partial plans obtained using this method are very similar to complete plans, and computing times are considerably reduced.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00099379
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 8:53:27 AM
Last modification on : Friday, February 26, 2021 - 3:28:05 PM
Identifiers
  • HAL Id : inria-00099379, version 1
Collections
Citation
Pierre Laroche. Building Efficient Partial Plans using Markov Decision Processes. International Conference on Tools with Artificial Intelligence, 2000, none, 19 p. ⟨inria-00099379⟩
Share
Metrics
Record views
81
