Derivation Schemes from OCL Expressions to B - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2002
Hung Ledang
  • Fonction : Auteur
  • PersonId : 835379
In the continuity of our research on integration of UML and B, we address in this paper the transformation from OCL (Object Constraint Language), which is part and parcel of UML, into B. Our derivation schemes allow to automatically derive in B not only the complementary class invariants, the guard conditions in state-charts (in OCL) but also OCL specifications OCL class operations, events or use cases.
Autre [cs.OH]
A02-R-042.pdf (137.59 Ko) Télécharger le fichier
inria-00099424 , version 1 (26-09-2006)
  • HAL Id : inria-00099424 , version 1
Hung Ledang, Jeanine Souquières. Derivation Schemes from OCL Expressions to B. [Intern report] A02-R-042 || ledang02b, 2002, 10 p. ⟨inria-00099424⟩
76 Consultations
131 Téléchargements
