Nonlinear blind source separation using kernels - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Neural Networks Année : 2003
Dominique Martinez
Alistair Bray
  • Fonction : Auteur
  • PersonId : 835393
We derive a new method for solving nonlinear blind source separation problems by exploiting second-order statistics in a kernel induced feature space. This paper extends a new and efficient closed-form linear algorithm to the non-linear domain using `the kernel trick' originally applied in Support Vector Machines. This technique could likewise be applied to other linear covariance-based source separation algorithms. Experiments on realistic nonlinear mixtures of speech signals, gas multisensor data and visual disparity data illustrate the applicability of our approach.
Fichier non déposé
inria-00099523 , version 1 (26-09-2006)
  • HAL Id : inria-00099523 , version 1
Dominique Martinez, Alistair Bray. Nonlinear blind source separation using kernels. IEEE Transactions on Neural Networks, 2003, 14 (1), pp.228-236. ⟨inria-00099523⟩
116 Consultations
0 Téléchargements
