Elitist identification of stops from formant transitions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Anne Bonneau
Yves Laprie
We present a set of strong cues for stop place of articulation, based upon formant transition slopes. This set complements a first one defined from stop bursts. Strong cues, which identify or eliminate a phonetic feature with certainty (no error is allowed), are not systematically fired. They can be exploited in language learning (cue enhancement) or in ASR to reduce the search space during the lexical access. The detection of the formant transitions and the cues is entirely automatic. To that purpose, we elaborate a robust formant tracking detector able to follow the transition trajectory. We obtained an average firing rate of 30 % on a clean corpus made up of sentences.
Autre [cs.OH]
Fichier non déposé
inria-00099616 , version 1 (26-09-2006)
  • HAL Id : inria-00099616 , version 1
Anne Bonneau, Yves Laprie. Elitist identification of stops from formant transitions. 15th International Congress of Phonetic Sciences - ICPhS'2003, Aug 2003, Barcelona, Spain, 4 p. ⟨inria-00099616⟩
49 Consultations
0 Téléchargements
