Polar varieties and computation of one point in each connected component of a smooth real algebraic set - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Let $f_1, \ldots, f_s$ be polynomials in $\Q[X_1, \ldots, X_n]$ that generate a radical ideal and let $V$ be their complex zero-set. Suppose that $V$ is smooth and equidimensional; then we show that computing suitable sections of the polar varieties associated to generic projections of $V$ gives at least one point in each connected component of $V\cap\R^n$. We deduce an algorithm that extends that of Bank, Giusti, Heintz and Mbakop to non-compact situations. Its arithmetic complexity is polynomial in the complexity of evaluation of the input system, an intrinsic algebraic quantity and a combinatorial quantity.
Fichier non déposé
inria-00099649 , version 1 (26-09-2006)
Mohab Safey El Din, Eric Schost. Polar varieties and computation of one point in each connected component of a smooth real algebraic set. International Symposium on Symbolic and Algebraic Computation 2003 - ISSAC'2003, Aug 2003, Philadelphie, PA, United States. pp.224-231, ⟨10.1145/860854.860901⟩. ⟨inria-00099649⟩
221 Consultations
0 Téléchargements
