RAMO Model Proposal v1.5
This document presents RAMO model proposals based on the RAMO Requirements Document that defines the main needed requirements related to the RAMO concept (document reference number: RAMO_RequirementsDocument_v4-0, 2003-10-29). It gathers the main modelling views by decomposing and analysing each of its requirements. It addresses design proposals. It consists in presenting the main directive ideas of the concept and in identifying the expected components capabilities of RAMO based on applications, scenes and objects. Next step is to work on a detailed design of each analysed requirement based on the main proposed solution presented in this document. This step prevails the expression of their requirements specification documents.
