HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Towards Realistic Implementations of External Memory Algorithms using a Coarse Grained Paradigm
Jens Gustedt 1
1 ALGORILLE - Algorithms for the Grid
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : We present an extension to SSCRAP, our C++ environment for the development of coarse grained algorithms, that allows for easy execution of programs in an external memory setting. Our environment is well suited for regular as well as irregular problems and scales from low end PCs to high end clusters and mainframe technology. It allows running algorithms designed on a high level of abstraction in one of the known coarse grained parallel models without modification in an external memory setting. The first tests presented here in this paper show a very efficient behavior in the context of out-of-core computation (mapping memory to disk files), and even some (marginal) speed up when used to reduced cache misses for in-core computation. || Nous présentons une extension de SSCRAP, notre environnement C++ pour le développement d'algorithmes à gros grain, qui permet une exécution facile de programmes dans le cadre d'utilisation de mémoire externe. Notre environnement est bien adapté à des prob
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00099787
Contributor : Jens Gustedt Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 9:41:14 AM
Last modification on : Friday, February 26, 2021 - 3:28:02 PM
Identifiers
  • HAL Id : inria-00099787, version 1
Collections
Citation
Jens Gustedt. Towards Realistic Implementations of External Memory Algorithms using a Coarse Grained Paradigm. International Conference on Computer Science and its Applications - ICCSA'2003, 2003, Montréal, Canada, pp.269-278. ⟨inria-00099787⟩
Share
Metrics
Record views
72
