Formal derivation of spanning trees algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Graphs algorithms and graph-theoretical problems provide a challenging battlefield for the incremental development of proved models. The B event-based approach implements the incremental and proved development of abstract models which are translated into algorithms; we focus our methodology on the minimum spanning tree problem and on Prim's algorithm. The correctness of the resulting solution is based on properties over trees and we show how the greedy strategy is efficient in this case. We compare properties proven mechanically to the properties found in a classical algorithms textbook.
Autre [cs.OH]
Fichier non déposé
inria-00099793 , version 1 (26-09-2006)
  • HAL Id : inria-00099793 , version 1
Jean-Raymond Abrial, Dominique Cansell, Dominique Méry. Formal derivation of spanning trees algorithms. Third International Conference of B and Z Users - ZB'2003, Marina Walden, 2003, Turku, Finland, pp.457-476. ⟨inria-00099793⟩
86 Consultations
0 Téléchargements
