HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
A model for co-operative planning within a virtual enterprise
Abstract : The paper presents a model for planning a virtual enterprise (VE). The partners of the VE, referred to as nodes of the VE (NEV), use negotiation and mediation principles to collaboratively elaborate consistent production plans. The proposed architecture of the VE is a set of levels corresponding to production cycles of products to be delivered by the VE to the customers. A multi-agent system is used to model the VE. For each level, a negotiator agent negotiates with NEV's of the same level. Each NEV is able to elaborate direct and backward planning, taking into account variation of demands and forecasts to guarantee a global benefit of the virtual enterprise. || Le papier propose un modèle pour la planification d'une entreprise virtuelle. Les partenaires de l'entreprise virtuelle utilisent la négociation pour élaborer collectivement des plannings consistants. L'architecture proposée comporte un ensemble de niveau
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00099823
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 9:41:33 AM
Last modification on : Friday, February 4, 2022 - 3:22:40 AM
Identifiers
  • HAL Id : inria-00099823, version 1
Collections
Citation
Latifa Ouzizi, Didier Anciaux, Marie-Claude Portmann, Francois B. Vernadat. A model for co-operative planning within a virtual enterprise. International Conference on Industrial Engineering and Production Management - IEPM'2003, Fucam, May 2003, Porto, Portugal, France. pp.209-220. ⟨inria-00099823⟩
Share
Metrics
Record views
85
