Designing event-driven systems by combining coordination and refinement - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
The coordination paradigm improves the development of concurrent/distributed solutions, because it provides a simple way to communicate between processes via a data structure called a tuple space. Coordination principles and event-driven system development principles can be fruitfully combined to develop systems and to analyse the development of different solutions of a given problem. Benefits are inherited from both frameworks : the B event-driven approach provides the refinement and the coordination framework provides a simple computation model. The sorting problem is redeveloped in the B event-driven method using coordination principles for algorithms and two programming paradigms are applied ie merging and splitting list to sort.
Autre [cs.OH]
Fichier non déposé
inria-00099835 , version 1 (26-09-2006)
  • HAL Id : inria-00099835 , version 1
Dominique Cansell, Dominique Méry. Designing event-driven systems by combining coordination and refinement. 2nd International Workshop on Refinement of Critical Systems: Methods, Tools and Developments - RCS'03, 2003, Turku, Finland. ⟨inria-00099835⟩
64 Consultations
0 Téléchargements
