Average case complexity analysis of RETE pattern-match algorithm and average size of join in Databases, 1989. ,
DOI : 10.1007/3-540-52048-1_46
URL : https://hal.archives-ouvertes.fr/inria-00075548
Algorithms for high level petri nets simulation and rule-based systems, Acta Universitaris Cibiniensis, vol.XLIII, pp.33-39, 2001. ,
A Rewriting Calculus for Cyclic Higher-order Term Graphs, Proceedings of the 2nd International Workshop on Term Graph Rewriting, 2004. ,
DOI : 10.1016/j.entcs.2005.01.034
URL : https://hal.archives-ouvertes.fr/inria-00100095
Term Rewriting and all That, 1998. ,
Production systems and rete algorithm formalisation, 2004. ,
URL : https://hal.archives-ouvertes.fr/inria-00099850
Jeops -the java embedded object production system, Lectures Notes in Artificial Intelligence, 1952. ,
Modelling planning problems with rules and strategies, 1999. ,
Rule based programming with constraints and strategies, ERCIM workshop on Constraints, 1999. ,
Objects, rules and strategies in ELAN, Proceedings of the second AMAST workshop on Algebraic Methods in Language Processing, 2000. ,
Rule Based Programming with Constraints and Strategies, New Trends in Constraints, Papers from the Joint ERCIM/Compulog-Net Workshop, Cyprus, pp.274-297, 1999. ,
Systèmes de r` egles de production et calcul de réécriture, 2001. ,
Contribution algorithmique a l'inference par regles de production, 1984. ,
Complete sets of unifiers and matchers in equational theories, Theoretical Computer Science, vol.43, issue.1, pp.189-200, 1986. ,
DOI : 10.1016/0304-3975(86)90175-1
Systèmes experts temps-réel: une introduction au langage xrete. Revue Technique Thomson-CSF, pp.23-3633, 1991. ,
Sémantique opérationnelle et compilation des systèmes de production. Revue d'intelligence artificielle, pp.6-4431, 1992. ,
A network fast routine for production systems. Working paper, 1974. ,
Ops5 user's manual, 1981. ,
Rete: A fast algorithm for the many pattern/many object pattern match problem, Artificial Intelligence, vol.19, issue.1, pp.17-37, 1982. ,
DOI : 10.1016/0004-3702(82)90020-0
Theory and practice of constraint handling rules. Special Issue on Constraint Logic Programming, pp.98-135, 1998. ,
Logic for Computer Science: Foundations of Automatic Theorem Proving, Computer Science and Technology Series. Harper & Row, vol.5, 1986. ,
An optimization algorithm for production systems, IEEE Transactions on Knowledge and Data Engineering, vol.6, issue.4, pp.6-4549, 1994. ,
DOI : 10.1109/69.298172
Vérification sémantique de spécifications métallurgiques, Inria Lorraine & Crin, 1993. ,
Rewriting, solving, proving. A preliminary version of a book available at www, 1999. ,
Real-time knownledge-based systems, 1989. ,
The Parallel Production System, 1987. ,
On the performance of lazy matching in production systems, Knowledge Presentation, pp.685-692, 1990. ,
Treat: a new and efficient match algorithme for AI production systems, 1990. ,
A Pattern-Matching Compiler, 1st International Workshop on Language Descriptions, Tools and Applications, 2001. ,
DOI : 10.1016/S1571-0661(04)80926-5
URL : https://hal.archives-ouvertes.fr/inria-00100437
Ilog jrules 4.6 technical white paper, 2004. ,
Rewrite semantics for production rule systems: Theory and applications, Proceedings 13th International Conference on Automated Deduction, pp.508-522, 1996. ,
DOI : 10.1007/3-540-61511-3_110
Term Rewriting Systems, 2002. ,
De l'efficacité des systèms de r` egles de production, 1990. ,
De l'efficacité des interpréteurs de systèms de r` egles de production dans les systèmessystèmes`systèmesà base de connaissances, 1994. ,
Eliminating expensive chunks by restricting expressiveness, Proceedings of the International Joint Conference on Artificial Intelligence, pp.431-456, 1989. ,
