Shuffling biological sequencess with motifs constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
We study the following problem : given a biological sequence S, a multiset M of motifs and an integer k, generate uniformly random sequences which contain the given motifs and have exactly the same frequencies occurrences of k-lets (i.e. factors of length k) of S. This question involves difficult problems: We notably state that the problem of deciding whether a sequence respects given motifs constraints is NP-complete. Meanwhile, we give a random generation algorithm which turns out to be experimentally efficient.
A04-R-272.pdf (214.06 Ko) Télécharger le fichier
inria-00099891 , version 1 (26-09-2006)
  • HAL Id : inria-00099891 , version 1
Dominique Barth, Johanne Cohen, Alain Denise, Romain Rivière. Shuffling biological sequencess with motifs constraints. Algorithms and Computational Methods for Biochemical and Evolutionary Networks - CompBioNets'2004, Dec 2004, Recife, Brazil. 18 p. ⟨inria-00099891⟩
113 Consultations
46 Téléchargements
