An analog Characterization of Elementarily Computable Functions Over the Real Numbers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
We present an analog and machine-independent algebraic characterizations of elementarily computable functions over the real numbers in the sense of recursive analysis: we prove that they correspond to the smallest class of functions that contains some basic functions, and closed by composition, linear integration, and a simple limit schema. We generalize this result to all higher levels of the Grzegorczyk Hierarchy. Concerning recursive analysis, our results provide machine-independent characterizations of natural classes of computable functions over the real numbers, allowing to define these classes without usual considerations on higher-order (type 2) Turing machines. Concerning analog models, our results provide a characterization of the power of a natural class of analog models over the real numbers.
Autre [cs.OH]
Fichier non déposé
inria-00099897 , version 1 (26-09-2006)
  • HAL Id : inria-00099897 , version 1
Olivier Bournez, Emmanuel Hainry. An analog Characterization of Elementarily Computable Functions Over the Real Numbers. 2nd APPSEM II Workshop - APPSEM'2004, 2004, Tallinn, Estonia, 12 p. ⟨inria-00099897⟩
114 Consultations
0 Téléchargements
