New interface
Journal articles
Efficient isolation of polynomial's real roots
Fabrice Rouillier 1, 2 Paul Zimmermann 2
1 CALFOR - Calcul formel
LIP6 - Laboratoire d'Informatique de Paris 6
2 SPACES - Solving problems through algebraic computation and efficient software
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : This paper revisits an algorithm isolating the real roots of a univariate polynomial using Descartes' rule of signs. It follows work of Vincent, Uspensky, Collins and Akritas, Johnson, Krandick. Our first contribution is a generic algorithm which enables one to describe all the known algorithms based on Descartes' rule of sign and the bissection strategy in a unified framework. Using that framework, a new algorithm is presented, which is optimal in terms of memory usage and as fast as both Collins and Akritas' algorithm and Krandick variant, independently of the input polynomial. From this new algorithm, we derive an adaptive semi-numerical version, using multi-precision interval arithmetic. We finally show that these critical optimizations have important consequences since our new algorithm still works with huge polynomials, including orthogonal polynomials of degree $1000$ and more, which were out of reach of previous methods.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00099941
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 10:12:45 AM
Last modification on : Friday, February 4, 2022 - 4:17:50 AM
Links full text
Identifiers
Citation
Fabrice Rouillier, Paul Zimmermann. Efficient isolation of polynomial's real roots. Journal of Computational and Applied Mathematics, 2004, 162 (1), pp.33-50. ⟨10.1016/j.cam.2003.08.015⟩. ⟨inria-00099941⟩
Share
Metrics
Record views
193
