Application of Markov Decision Processes to the Frequency Assignment Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Artificial Intelligence Année : 2004
Jean-Yves Greff
  • Fonction : Auteur
Lhassane Idoumghar
René Schott
  • Fonction : Auteur
  • PersonId : 835418
This paper presents an original algorithm, based on Markov Decision Processes, that is used to solve the frequency assignment problem in the field of radiobroadcasting. The results that are obtained by this algorithm are compared to the best known results obtained by hybrid genetic algorithm, ant colony paradigms and the best operating solution in the field of radiobroadcasting in France.
Autre [cs.OH]
inria-00099975 , version 1 (26-09-2006)
Jean-Yves Greff, Lhassane Idoumghar, René Schott. Application of Markov Decision Processes to the Frequency Assignment Problem. Applied Artificial Intelligence, 2004, 18 (8), pp.761-773. ⟨10.1080/08839510490497058⟩. ⟨inria-00099975⟩
73 Consultations
0 Téléchargements
