HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Improved hit criteria for DNA local alignment
Laurent Noé 1 Gregory Kucherov 1
1 ADAGE - Applying discrete algorithms to genomics
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : The hit criterion is a key component of heuristic local alignment algorithms. It specifies a class of patterns assumed to witness a potential similarity, and this choice is decisive for the selectivity and sensitivity of the whole method. In this paper, we propose two ways to improve the hit criterion. First, we define the group criterion combining the advantages of the single-seed and double-seed approaches used in existing algorithms. Second, we introduce transition-constrained seeds that extend spaced seeds by the possibility of distinguishing transition and transversion mismatches. We provide analytical data as well as experimental results, obtained with the YASS software, supporting both improvements.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00099999
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 10:13:17 AM
Last modification on : Friday, February 4, 2022 - 3:30:03 AM
Identifiers
  • HAL Id : inria-00099999, version 1
Collections
Citation
Laurent Noé, Gregory Kucherov. Improved hit criteria for DNA local alignment. Proceedings of the 5th Open Days in Biology, Computer Science and Mathematics - JOBIM'2004, 2004, Montreal, Canada, 11 p. ⟨inria-00099999⟩
Share
Metrics
Record views
54
