An Integrated Development Environment for Pattern Matching Programming
Tom and Apigen are two complementary tools which simplify the definition and the manipulation of abstract datatypes. Tom is an extension of Java which adds pattern matching facilities independently of the used data-structure. Apigen is a generator of abstract syntax tree implementations which interacts naturally with \tom. In this paper, we show how Eclipse can be extended to support the development of Tom programs. By integrating a Tom editor, an automatic build process, and an error management mechanism, we demonstrate the integration of an algebraic programming environment in Eclipse. Hence, our work contributes to the promotion of formal methods and Eclipse to the educational, algebraic, and industrial communities.
