New interface
Journal articles
Alpha-Jacobian environmental adaptation
Christophe Cerisara 1 Luca Rigazio 2 Jean-Claude Junqua 2
1 PAROLE - Analysis, perception and recognition of speech
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : The robustness of automatic speech recognition systems to noise is still a problem, especially for small footprint systems. This paper addresses the problem of noise robustness using model compensation methods. Such algorithms are already available, but their complexity is usually high. An often referenced method for achieving noise robustness is Parallel Model Combination (PMC). Several algorithms have been proposed to develop more computationally efficient methods than PMC. For example, Jacobian adaptation approximates PMC with a linear transformation function in the cepstral domain. However, the Jacobian approximation is valid only for test environments that are close to the training conditions whereas, in real test conditions, the mismatch between the test and training environments is usually large. In this paper, we propose two methods, respectively called static and dynamic alpha-Jacobian adaptation (or alpha-JAC), to compute new linear approximations of PMC for realistic test environments. We further extend both algorithms to compensate for additive and convolutional noise and we derive the corresponding non-linear algorithm that is approximated. All these algorithms are experimentally compared in important mismatch conditions. As compared to Jacobian adaptation, improvements are observed with both static and dynamic alpha-Jacobian adaptation.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00100034
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 10:13:33 AM
Last modification on : Friday, November 18, 2022 - 9:23:59 AM
Identifiers
  • HAL Id : inria-00100034, version 1
Collections
Citation
Christophe Cerisara, Luca Rigazio, Jean-Claude Junqua. Alpha-Jacobian environmental adaptation. Speech Communication, 2004, 42 (1), pp.25-41. ⟨inria-00100034⟩
Share
Metrics
Record views
110
