The virtual mesh: A geometric abstraction for efficiently computing radiosity, ACM Transactions on Graphics, vol.20, pp.3-169, 2001. ,
Applications of random sampling to on-line algorithms in computational geometry, Discrete and Computational Geometry, vol.8, pp.1-51, 1992. ,
Error Control for Radiosity, Rendering Techniques '96 (7th Eurographics Workshop on Rendering), pp.153-164, 1996. ,
A novel approach makes higher order wavelets really efficient for radiosity, Computer Graphics Forum, vol.19, issue.3, pp.99-108, 2000. ,
Computational Geometry Algorithms Library ,
Robust epsilon visibility, ACM Transactions on Graphics, vol.21, issue.3, 2002. ,
Fast and accurate hierarchical radiosity using global visibility, ACM Transactions on Graphics, vol.18, issue.2, pp.128-170, 1999. ,
The 3d visibility complex, ACM Transactions on Graphics, vol.21, issue.2, 2002. ,
Combining Higher-Order Wavelets and Discontinuity Meshing for Radiosity A Fast Shadow Algorithm for Area Light Sources Using Backprojection, Computer Graphics Proceedings, Annual Conference Series, (ACM SIGGRAPH '94), pp.223-230, 1994. ,
Accurate Visibility and Meshing Calculations for Hierarchical Radiosity, Rendering Techniques '96 (7th Eurographics Workshop on Rendering), pp.269-278, 1996. ,
Wavelet Radiosity, Computer Graphics Proceedings, Annual Conference Series, (ACM SIGGRAPH '93), pp.221-230, 1993. ,
Discontinuity Meshing for Radiosity, Third Eurographics Workshop on Rendering, pp.203-226, 1992. ,
Discontinuity Meshing for Complex Environments, 1998. ,
A Rapid Hierarchical Radiosity Algorithm for Unoccluded Environments, Photorealism in Computer Graphics (Proceedings Eurographics Workshop on Photosimulation, Realism and Physics in Computer Graphics, pp.151-171, 1990. ,
A Rapid Hierarchical Radiosity Algorithm, Computer Graphics (ACM SIGGRAPH '91), pp.197-206, 1991. ,
Selective culling of discontinuity lines, Rendering Techniques '97, pp.69-80, 1997. ,
Ray Tracing Volume Densities, Computer Graphics (ACM SIGGRAPH ', vol.84, issue.3, pp.165-174, 1984. ,
Discontinuity Meshing for Accurate Radiosity, IEEE Computer Graphics and Applications, vol.12, issue.6, pp.25-39, 1992. ,
Combining Hierarchical Radiosity and Discontinuity Meshing, Computer Graphics Proceedings, Annual Conference Series, (ACM SIGGRAPH '93), pp.199-208, 1993. ,
Discontinuity Meshing and Hierarchical Multiwavelet Radiosity, Graphics Interface '95, pp.109-115, 1995. ,
Wavelet Projections for Radiosity, 4th Eurographics Workshop on Rendering, pp.105-114, 1993. ,
Getting rid of links in hierarchical radiosity, Computer Graphics Forum, vol.17, issue.3, pp.165-174, 1998. ,
Adaptive Mesh Refinement with Discontinuities for the Radiosity Method, Photorealistic Rendering Techniques (5th Eurographics Workshop on Rendering), pp.239-248, 1994. ,
OpenGL Programming Guide: The Official Guide to Learning OpenGL, Version 1.4, 2003. ,
An Empirical Comparison of Progressive and Wavelet Radiosity, Rendering Techniques '97, pp.175-186, 1997. ,
DOI : 10.1007/978-3-7091-6858-5_16
