Competitive Memetic Algorithms for Arc Routing Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annals of Operations Research Année : 2004
The Capacitated Arc Routing Problem or CARP arises in applications like waste collection or winter gritting. Metaheuristics are tools of choice for solving large instances of this NP-hard problem. The paper presents basic components that can be combined into powerful memetic algorithms (MAs) for solving an extended version of the CARP (ECARP). The best resulting MA outperforms all known heuristics on three sets of benchmark files containing in total 81 instances with up to 140 nodes and 190 edges. In particular, one open instances are broken by reaching a tight lower bound designed by Belenguer and Benavent, 26 solutions are improved, and all other best-known solutions are retrieved.
Fichier non déposé
inria-00100062 , version 1 (26-09-2006)
  • HAL Id : inria-00100062 , version 1
Philippe Lacomme, Christian Prins, Wahiba Ramdane-Cherif. Competitive Memetic Algorithms for Arc Routing Problems. Annals of Operations Research, 2004, 131 (1-4), pp.159-185. ⟨inria-00100062⟩
140 Consultations
0 Téléchargements
