HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Tutorial on the event-based B method : Concepts and Case Studies
Dominique Cansell 1 Dominique Méry 1
1 MOSEL - Proof-oriented development of computer-based systems
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : B is a method for specifying, designing and coding software systems. It is based on Zermelo-Fraenkel set theory with the axiom of choice, the concept of generalized substitution and on structuring mechanisms (machine, refinement, implementation). The concept of refinement is the key notion for developing B models of (software) systems in an incremental way. B models are accompanied by mathematical proofs that justify them. Proofs of B models convince the user (designer or specifier) that the (software) system is effectively correct. We provide a survey of the underlying logic of the B method and the semantic concepts related to the B method ; we detail the B development process partially supported by the mechanical engine of the prover.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00100065
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 10:13:49 AM
Last modification on : Friday, February 4, 2022 - 3:30:04 AM
Identifiers
  • HAL Id : inria-00100065, version 1
Collections
Citation
Dominique Cansell, Dominique Méry. Tutorial on the event-based B method : Concepts and Case Studies. Logics of Formal Software Specification Languages - LFSL'2004, 2004, The High Tatras, Slovakia. ⟨inria-00100065⟩
Share
Metrics
Record views
123
