Abstract : Within the scope of the REMPLI Project, a SFN Network Management System is developed. But the SFN is a new technology and never tested outside of laboratory. If the field trail is based only on SFN technology the risk is too high. Therefore we decided to develop in parallel a classical routing based network management system based on the proofed concept of (in the following this is called DLC-100 2C NMS). Both systems should be orientated towards the same software architecture. It should be reached that both systems (SFN NMS, DLC-100 2C NMS) have the same tasks like take-over data of the application, data segmentation and data composition, high priority transfer of the OFDM blocks to the DSP etc., which are realised in common modules, that are integrated in the respective software. They will be extended, by additional project-dependent functions, on demand. On the other hand, the NMS specific tasks will be programmed in separate modules.
