Role-Based Access Control for XML Enabled Management Gateways - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
While security is often supported in standard management frameworks, it has been insufficiently approached in most deployment and research initiatives. In this paper we address the provisioning of a security ``continuum'' for management frameworks based on XML/SNMP gateways. We provide an in depth security extension of such a gateway using the Role Based Access Control paradigm and show how to integrate our approach within a broader XML-based management framework.
Fichier non déposé
inria-00100139 , version 1 (26-09-2006)
  • HAL Id : inria-00100139 , version 1
Vincent Cridlig, Radu State, Olivier Festor. Role-Based Access Control for XML Enabled Management Gateways. 15th IFIP/IEEE Distributed Systems: Operations and Management - DSOM 2004, UC Davis, 2004, Davis, CA, USA, pp.183-195. ⟨inria-00100139⟩
93 Consultations
0 Téléchargements
