Using semi-implicit representation of algebraic surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
Laurent Busé
André Galligo
  • Fonction : Auteur
  • PersonId : 835184
In a previous work we introduced a new general representation of algebraic surfaces, that we called semi-implicit, which encapsulates both usual and less known surfaces. Here we specialize this notion in order to apply it in Solid Modeling: we view a surface in the real space as a one-parameter (algebraic) family of algebraic low-degree curves. The paper mainly addresses the topic of performing the usual CAD operations with semi-implicit representation of surfaces. We derive formulae for computing the normal and the curvatures at a regular point. We provide exact algorithms for computing self-intersections of a surface and more generally its singular locus. We also present some surface/surface intersection algorithms relying on generalized resultant calculations.
detailed-smi04.pdf (806.08 Ko) Télécharger le fichier
smi04.pdf (61.16 Ko) Télécharger le fichier
inria-00100310 , version 1 (26-09-2006)
  • HAL Id : inria-00100310 , version 1
Laurent Busé, André Galligo. Using semi-implicit representation of algebraic surfaces. Shape Modeling and Applications Conference, Jun 2004, Genova, Italy. pp.342-345. ⟨inria-00100310⟩
134 Consultations
375 Téléchargements
