Automatic Multithreaded Parallel Program Generation for Message Passing Multiprocessors Using Parameterized Task Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
In this paper we describe a code generator prototype that uses parameterized task graphs (PTGs) as an intermediate model and generates a multithreaded code. A PTG is a compact and a problem size independent representation of some task graphs found in scientific programs. We show how, with this model, we can generate a parallel program that is scalable (it is able to execute million of tasks) and generic (it works for all parameter values).
Fichier non déposé
inria-00100489 , version 1 (26-09-2006)
  • HAL Id : inria-00100489 , version 1
Emmanuel Jeannot. Automatic Multithreaded Parallel Program Generation for Message Passing Multiprocessors Using Parameterized Task Graphs. Parallel Computing 2001 - ParCo'2001, 2001, Naples, Italy, 8 p. ⟨inria-00100489⟩
61 Consultations
0 Téléchargements
