Data oriented genetic operators for one-machine scheduling problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
We consider the one machine scheduling problem with identical release dates, sequence dependent set-up times and weighted sum of performance as performance measure. We propose new genetic operators called "data oriented" that use not only the permutation contained in the chromosome but also an analysis of the corresponding solution. The experimental results show that data oriented operators are globally better than calssical ones.
Fichier non déposé
inria-00100510 , version 1 (26-09-2006)
  • HAL Id : inria-00100510 , version 1
Marie-Claude Portmann, Mohamed Ali Aloulou. Data oriented genetic operators for one-machine scheduling problems. Proceedings of the Genetic and Evolutionary Computation Conference - GECCO'2001, 2001, San Francisco, CA, USA, pp.1184. ⟨inria-00100510⟩
59 Consultations
0 Téléchargements
