Locked and Unlocked Polygonal Chains in Three Dimensions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Computational Geometry Année : 2001
This paper studies movements of polygonal chains in three dimensions whose links are not allowed to cross or change length. Our main result is an algorithmic proof that any simple closed chain that initially takes the form of a planar polygon can be made convex in three dimensions. Other results include an algorithm for straightening open chains having a simple orthogonal projection onto some plane, and an algorithm for making convex any open chain initially configured on the surface of a polytope. All our algorithms require only O(n) basic ``moves.''
Autre [cs.OH]
inria-00100521 , version 1 (26-09-2006)
Thérèse Biedl, Erik Demaine, Martin Demaine, Sylvain Lazard, Anna Lubiw, et al.. Locked and Unlocked Polygonal Chains in Three Dimensions. Discrete and Computational Geometry, 2001, 26 (3), pp.269-281. ⟨10.1007/s00454-001-0038-7⟩. ⟨inria-00100521⟩
81 Consultations
0 Téléchargements
