Optimal routing of continuous timed Petri nets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
In this paper, we consider deterministic timed continuous Petri nets where conflicts at places are solved by assigning stationary routing parameters. We show how to compute the stationary firing rate at all transitions as well as how to determine the optimal routing parameters to maximize the firing rates. Finally, we discuss the relations with discrete Petri nets.
A02-R-320.pdf (149.63 Ko) Télécharger le fichier
inria-00099456 , version 1 (26-09-2006)
  • HAL Id : inria-00099456 , version 1
Bruno Gaujal, Alessandro Giua. Optimal routing of continuous timed Petri nets. IFAC 2002 - 15th World Congress on Automatic Control - B'02, Jul 2002, Barcelona, Spain. pp.6. ⟨inria-00099456⟩
149 Consultations
239 Téléchargements
