Direct phasing by binary integer programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2001
Vladimir Y. Lunin
  • Fonction : Auteur
Alexandre Urzhumtsev
  • Fonction : Auteur
The phase problem is one of the major problems in crystallography. In the absence of phase information, a variety of electron density distributions is consistent with the observed magnitudes. This ambiguity may be reduced significantly if the distribution values are restricted to 0 or 1 values, i.e. when the object of search is an envelope rather than a continuous electron density distribution. The density values are linked to the observed magnitudes and unknown phases by a system of non­linear equations. We present a method to replace these equations by a system of linear inequalities. As a consequence, powerful tools of integer linear programming may be applied to solve the phase problem. This novel approach was tested on calculated and experimental data for a known protein structure. At the moment, the size of the grid for the envelope calculation is the major limitation of the approach. Nevertheless, even for a very small grid, some structure information can be extracted and used as a starting point for further phase improvement or as a way to solve the molecular replacement problem.
Fichier non déposé
inria-00100701 , version 1 (26-09-2006)
  • HAL Id : inria-00100701 , version 1
Vladimir Y. Lunin, Alexandre Urzhumtsev, Alexander Bockmayr. Direct phasing by binary integer programming. [Intern report] A01-R-307 || lunin01a, 2001, 12 p. ⟨inria-00100701⟩
58 Consultations
0 Téléchargements
