From a biological to a computational model for the autonomous behavior of an animat - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Information Sciences Année : 2002
Hervé Frezza-Buet
Frédéric Alexandre
Endowing an autonomous system like a robot with intelligent behavior is a difficult problem for several reasons. First, behavior is such a wide topic that a general framework paradigm of inspiration must be chosen in order to obtain a consistent model. Such a framework can be for example biological modeling or an artificial intelligence approach. Second, a general framework is not sufficient to determine a fully specified program to be implemented in a robot. Many choices, tuning and tests must be carried out before obtaining a robust system. This paper describes this.
inria-00100715 , version 1 (26-09-2006)
Hervé Frezza-Buet, Frédéric Alexandre. From a biological to a computational model for the autonomous behavior of an animat. Information Sciences, 2002, 144 (1-4), pp.1-43. ⟨10.1016/S0020-0255(02)00195-0⟩. ⟨inria-00100715⟩
104 Consultations
0 Téléchargements
