Knowledge extraction using artificial neural networks: Application to radar target identification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Signal Processing Année : 2002
Artificial neural networks are efficient for performing signal processing but are not able to explain their decision nor to extract knowledge from data. We propose here a way to extract rules and hints from the hidden layers of a multilayered perceptron. The network is first pruned and then the progressive use of a simpler transfer function can allow such knowledge extraction. This method has been successfully applied to radar signal identification.
inria-00100719 , version 1 (26-09-2006)
Jean-Francois Remm, Frédéric Alexandre. Knowledge extraction using artificial neural networks: Application to radar target identification. Signal Processing, 2002, 82 (1), pp.117-120. ⟨10.1016/S0165-1684(01)00142-6⟩. ⟨inria-00100719⟩
107 Consultations
0 Téléchargements
