HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Binary integer programming and its use for envelope determination
Vladimir Y. Lunin Alexandre Urzhumtsev Alexander Bockmayr 1
1 MODBIO - Computational models in molecular biology
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : The density values are linked to the observed magnitudes and unknown phases by a system of non-linear equations. When the object of search is a binary envelope rather than a continuous function of the electron density distribution, these equations can be replaced by a system of linear inequalities with respect to binary unknowns and powerful tools of integer linear programming may be applied to solve the phase problem. This novel approach was tested with calculated and experimental data for a known protein structure.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00100778
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Tuesday, September 26, 2006 - 2:50:58 PM
Last modification on : Friday, February 4, 2022 - 3:30:39 AM
Identifiers
  • HAL Id : inria-00100778, version 1
Collections
Citation
Vladimir Y. Lunin, Alexandre Urzhumtsev, Alexander Bockmayr. Binary integer programming and its use for envelope determination. CCP4 Newsletter on Protein Crystallography, CCP, 2002, 9 p. ⟨inria-00100778⟩
Share
Metrics
Record views
38
